Manually configure the port speed.
Important
If Auto-Negotiation is disabled and you change the speed on a port that results in a configuration mismatch in speed between two ports, VSP 4900 Series switches may show an incorrect operational status of "up" for the mismatched ports.
The following table defines parameters for the speed command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Specifies the port or ports that you want to configure. |
10 |
Configures the port speed to 10 Mbps. |
100 |
Configures the port speed to 100 Mbps. |
1000 |
Configures the port speed to 1 Gbps. |
10000 |
Configures the port speed to 10 Gbps. |
2500 |
Configures the port speed to 2.5 Gbps. |
25000 |
Configures the port speed to 25 Gbps. |
5000 |
Configures the port speed to 5 Gbps. |
